2005 Silverado Hard 1-2 shift when warmed up
2005 5.3 1500 4X4 Auto
1-2 Shift when cold is smooth, no issues. Once warmed up though it holds first too long and bangs into second a bit hard. 2-3 and 3-4 are smooth.
Transmissing is a "gm factory rebuild" according to the sticker on it, out of an Avalanche. My original transmission crapped out 2 years ago. This one came out of an Avalanche with 75k miles on it, but also has a factory rebuild sticker on it but unknown when that was done.
Fluid is fresh from the install of the transmission about 10,000 mlies ago, DEX 6 from the dealer.
Any solid ideas on this issue? No check engine light illuminated.
If dealer installed, I'd let them look at it and make programming adjustments. Line pressure may be a bit high.
