06 1500HD speaker update advise needed
I have an 06 1500HD Crew Cab with Bose. I replaced the head unit with a Pioneer AppRadio a few months back and everything was great the system was even louder than stock.
Now one of my rear speakers in the door is buzzing when listening to spoken word podcasts or audio books.
I am now looking at replacing all the speakers. I am looking for some advise on how to proceed.
I checked Crutchfield.com to see what fits. It looks like the backdoors are the tough ones. The fronts are 6.5 or 6.75” and the rears are up to 6.5”. I was looking RF Punch speakers but they only showed a component system and I don’t see how a component would fit there without a lot of mods. I tried chatting with their advisors and they said not many speakers fit in the rear door because of the depth and the grill. He said most of the tweeters on 2way and 3way speakers stick out too far and would impact the stock speaker grill. He suggested Polk Audio db651s.
Now the questions:
· Any suggestions on speakers to use? I want to stay around $100 per set but I am open to suggestions
· Will the Bose amp screw the setup? I read that the Bose are 2-ohm setups.
· Should I use the components in the front and put the tweeter in stock location?
· If I use 2 or 3 ways will all of the tweeters screw the sound?
What have others done in their similar trucks?
I would replace the fronts with a nice set of components. The factory speaker location and tweeter location will handle any component setup just fine with some fab work. Its really not that serious. I would go with a 2 way speaker for the rear. No need for 3 ways. 99% of people cannot hear the difference anyways.
I however would not run these speakers on the factory amp. The lower resistance will shorten the life of the speakers, and probably cause distortion at higher volumes. The best thing to do is replace factory bose amp with a small aftermarket 4 channel. It doesnt have to be anything super fancy, just something to give the speakers some life. I guarantee you will not like the aftermarket speakers on just radio power. They'll just sound like tweeters.
I've been doing this a very long time and its not worth it to skip around certain things. And most people want expensive amps and components, but they couldn't tell the difference in sound quality. You're not an audiophile, dont spend money like one. Just buy decent stuff and dont over do it on the volume and you'll be fine.
I cannot speak about Polk's quality these days, but they used to be average back in the day, nothing great. I really like Kenwood Excelon door speakers. They're a little more than regular line speakers, but handle a lot more power and last a lot longer. I've been using them for 12 years now, and never had a problem. I about to install them in the same truck now, hopefully they clear the rear doors.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
