Removing Airbag on 1999 Sierra
I have a 199 GMC Sierra. My horn does not work, I know the problem is in the horn on wheel. The horms arte new and work with alarm. I think the contacts need cleaning or a wire. Checked all fuses, relays, etc.
I know there are 2 slits on the back of the steering wheel to remove airbag?
How do I go about removing the airbag.
Thanks in advance
Gliss
