GMC VIN build sheet request
hey all new here just picked up an 01 2500hd and was looking to get build and history on my new truck any help would be great thanks in advance
hey thanks for your vin, i just put a shop keepers lean on it for 8000 dollars. lol j/k
ive seen others post request here and get all the info here. as far as jackin my vin you could get all that info from trader online so not that big of a deal.. just sayin
You need to go to your dealer to obtain this info
Ryan
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
