WreckedExotics.com
TxDoc
wreckedexotics.com --------go to the "bad wrecks" or "weird wrecks" pages.
Well...I didn't check, but I'm sure they would post it.
But I dont know Mervz, so I will let you suggest he relive his pain for the enjoyment of others.
I wonder if anyone ever added up the total value of all the dead cars on that site.
I bet its at least $1.62.
Want to hear something weird!?
I know THIS guy, and rode in THIS car.  :cheers:  :cheers:  :chevy:
I know THIS guy, and rode in THIS car.  :cheers:  :cheers:  :)
what's weirder is he just barely bumped that 4" curb and look at all the damage it did to his viper  :chevy:
Just messing w/ ya zane, I remember you talking about riding in his car and then it seemed like less than a week later you were showing us the pic of it.
    Gkistler
    Gkistler
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
