Front mounted hitch
Im looking into a frount hitch for my XL, wondering if anybody has one, or a picture of one installed.  I wanna know how low it hangs, and how much it sticks out.  Im just tired of towing in drive, I thought I would try it in reverse :cheers:
Click Here
<http://www.jcwhitney.com/images/imagecache/I9433.gif>       FRONT-MOUNT CLASS III 2" RECEIVER HITCH
   * Carry hitch-mounted accessories and tow a trailer?at the same time!
   * Accepts most 2" hitch accessories (bike racks, winch plates, cargo carriers, etc.)
   * Move and spot trailers easier in tight spaces
Tubular steel construction. Rust-resistant finish exceeds 500 hours of salt-spray testing?or 5 winters. 9,000-lb. winch line rating and 500-lb. tongue weight rating (except where noted). No drilling or trimming of body parts (except where noted). Because of close tolerances, installation of hitch on vehicles with bumper or front-end damage not recommended. Easy bolt-on installation. No welding required. Limited lifetime warranty. NOTE: SKU numbers ending in F are factory shipped and may take a little longer to reach you.
The Hidden Hitch one comes out in the slot of the front air dam unless you mount it as for the stock 1500 Silverado, then it hangs about 3 inches below the airdam.  I have this on my Silverado.    I put the HD airdam on it so it comes out the slot in the middle of the airdam.  Here is how they look on a Tahoe Military Tahoe pic
Hey3/4TonYukonXL,
I don't have any info regarding your hitch question, but I saw in your signature that you have custom clear headlights.  I just bought a 2003 yukon, and I want to put clear headlights on it, but, to my amazement, no one makes them.  How did you get yours clear?  And what brand are your clear corners?
Thanks in advance.
I've got one on my F150.  It is for a winch....it can be mounted on the front or back.  When it was installed, they simply cut a square hole in the air dam and its there...I plan on getting a hitch plug for it eventually.
