2001 Crew Cab and Airbags
Ok I got a question ...has anyone tried to add the Passenger Airbag key switch to there truck ?
The owners manual says a child is ok in the front seat as long as the seat is all the way back and not in a rear facing car seat......
I take my daughter with me alot just me and her and I usually let her sit up with me but we have a few rules........but still I would like to be able to turn it off........You'd think one out of a Ex cab or reg. cab would just plug in all you would have to do is get it keyed?
I think I remember it being done before...  I look and see if I can't find the info for you.  Hopefully someone else has the info handy and can jump in and pass "the word".
As far as I know it would just plug in and not have to be keyed. I had a company truck from my previous employer and the keys would work in either airbag switch.
Is there a fuse you can pull? I did that in one of my trucks.  The airbag light stays on, but it disabled it!  But that one fuse may go to other things too.
We just had a customer buy a vette and she gets her airbag turned off by a co. here in Dallas. You can call some dealerships in the your to see if they know anyone that will install an on off switch, but i'm positive they won't do it for liability reasons (we won't).
I realy don't like messing with the airbags at all.  I install some alarms and such, and I make it a point not to touch or disconnect any of the airbag wiring.  I've heard that they have gone off in the past when installers mess with the wiring.  If you do decide to get it done, maybe have a professional do it, or follow the directions to a T!
I had my dealer run my '03 vin number to get the right switch.  The wiring is hanging behind the dash.  It's a $60.00 part for the switch.  I haven't gotten it yet and am unsure how to plug it in without accidentally setting it off.  I want to ask a body shop first.  They must know of a safe way to deal with airbags and wiring.
Thanks Everyone..I am going out to the body shop to have my Visor painted and installed and will ask what they think..I don't see think it would be a big deal.....I tried my key to lock out the airbag in a buddies work truck and it worked......
    Greg3160
    Greg3160
  • Who's Online   4 Members, 0 Anonymous, 870 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
