Changing the starter
I have a 1997 GMC 2500 Diesel 4x4. I am in process of changing the starter. Just need to know if I need to remove Bell Housing cover to get the old starter off. It has been a pisser to get the small nut off the front of the old starter, and now I am unable to remove the old unit. I don't want to remove the bell housing cover unless needed....any help out there?
Have the same year ,remove all the bell housing bolts so it is loose just so it will move around,i leave bracket on starter and take bolt out of the engine block,up near frost plug then starter will move towards front of engine and drop down ,very tight fit,Wires are a pain to get off also.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
