dome light flickering
I have noticed that when the truck is running and i open the door the dome light flickers really fast.. anyone else have this problem and How should i fix it.
Try replacing the bulb first. You can just swap out another bulb to the same loction and see if it happens or not. Odds are the filament is just weak. If you have LEDs, the LEDs could just be going bad. It happens.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
