1995 GMC Yukon Idle Surge When Warm
1995 GMC Yukon (non-Vortec), ongoing for about a year, after truck was taken out of storage for 13 months:
Always smells a little rich.
Cold start – Long cranking, smooth idle. Smells very rich.
Warm start - no codes, no SES light, warm start (30 minutes off after full hot), short cranking, initial smooth idle; surging idle starts after 20 seconds. Feels like stalling, then catches itself and goes up to 800 RPM, then drops and repeats. Smooth idle and ride after about 1 minute. Smells rich/flooded. Not as bad in the summer, but very bad in cool weather.
Overall, it seems like something heats up, cools off, but not all the way cold, then either malfunctions or gives a bad reading to the computer which creates the surging. After a minute, it either warms up enough to stop malfunctioning or giving the computer bad info.
I have been to nine shops and they can all duplicate the symptoms, but can not track the source.
Thank you for any help!
No change after any of these fixes:
03 Jan 2012
Replace Coolant Temp Sensor
Replace coolant temp sensor connector
11 Jan 2012
PCV replace
12 Jan 2012
Replace Fuel pressure regulator
Replace driver’s side (left) fuel injector; it was dripping
14 Jan 2012
Clean air filter
24 Jan 2012
Replace Dist cap and rotor
Replace ignition coil
Replace Ignition Control Module
Tighten Idler Air Control Motor
31 Jan 2012
Replace IAC and pigtail
Replace O2 sensor
08 Feb 2012
Replace fuel pump
Replace fuel pump sending unit module
05 March 12
Replace fuel filter
08 March 12
Replace Spark Plugs (AC Delco Rapid Fire #1)
Replace Spark plug wires and heat shields
10 April 2012
Removed Jet chip to aid diagnostics
Replace Throttle Position Sensor
Replace PCV hose
Replace elbow on rear of TBI crankcase breather hose
25 April 2012
Replace MAP Sensor AC Delco
01 June 2012
Replace vacuum hose from A/C accumulator to heater control valve.
02 July 2012
Replaced TBI plastic ring and rear breather vent hose
Sea Foam spray into TBI
30 Nov 2012
Re-install Jet chip
Replace EGR valve
That's the heck of a replacement parts list.
I didn't see catalytic converter on there, it could be plugged and you say it smells rich. If its not burning any of the unburnt fuel that could be where your rich smell is coming from. Just a thought.
Suprisingly, the cat converter started to rattle about a week ago. So, solves the problem or not, a new one is on the way. Thank you.
I think whenever I do solve this, I will be so excited that I will tell the world! I have seen similar issues on other websites, but there is never a closing solution.
    Markey
    Markey
  • Who's Online   2 Members, 0 Anonymous, 2,516 Guests (See full list)
