iPhone 5, iOS6 with UUI radio
Can anyone confirm that this combo works via lightning connection to USB? Specifically, I'm wondering does the iPod & Pandora functions transmit data to the H/U and retain control through the H/U & steering wheel controls?
I searched several times & saw nothing as it relates to this specifically.
Just a quick heads up, you might want to change your pic, very family oriented sight and the mods don't tolerate much; Just a quick, helpful suggestion.
FYI, yes it does. All sources so far show up on the H/U's display. Confirmed with Pandora, Slacker, iHeartRadio, Amazon Cloud player. All but iHeartRadio show track, artist, album, total time & time elapsed. You can advance & go back via steering wheel controls, but you do have to change playlists/channels via the phone's touch screen.
Pretty nifty.
Just a quick follow up: Spotify streams through & displays the current info when first connected. However, it updates the info on the display intermittently. You can control track advance & back with the steering wheel controls and all the songs play, but the song info on the display rarely updates. On Sirius/XM the audio plays, but channel/show/track info does not synch with the display.
YMMV
