Need help writing a speech
Jpshostr
Hey I'm writing my final exam speech for my speech class.  I'm giving it tomorrow in class, and I need some facts, good info as why to get the Silverado over the F-150.  If anyone could help me with some info that'd be great, some people in that class are Ford fans :0 .
Lower step-in (step-up) height in Chevy.  In extended cab models, a back seat that is actually useable by adults.  (My 6'3" son used to sit in the back of my Sierra.)  Quality studies have found Ford quality to be slipping.  I work with a number of folks who get Ford employee and family discounts and they have cited quality problems.
Good luck on your speech.
Don't forget safety, it's always a good selling point on these types of speeches.  The F-150 was the most unsafe truck for accidents and silverado was the best american truck.
For more info I would just print out the specs on both trucks and compare price, options, engines, etc...
And Good Luck.
Well thanks for your help.  I'm writing the speech next period in Auto and giving it the next period, only has to be 5 minutes long at max, so it should be to bad.  I'm going to give some specs, but mostly focus on the crash test data.
Let me get this straight...you mention that this is your "final exam" speech.  You are going to prepare it next period while sitting in another class.  You are then going to present it the NEXT period????
You gotta adminre those fly by the seat of the pants guys!!!!!
My favorite quote, from my senior high school yearbook page till today -
"Nothing makes a person more productive than the last minute"
Words to live by, author unknown
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
