extendable mirrors for 2011 silverado
TTTim
I have a 2011 silverado with normal mirrors ( heated power no signal) I wish to install extendable mirrors with power heat and add signals , is the wiring harness all set for signals or is this something that needs modification? and does anyone have a set of takeoffs that will work?
    Thanks in advance guys
    Tim
Yes the wiring is there. Just put a pair of fit system mirrors on mine with signal and it's plug and play.
Sent from HTC using tapatalk 2.
I have a guide I wrote for this task in my signature. Check it out.
