Blower Motor replace
How hard is it to replace the blower motor in a 99 Sierra? Mine has periods of loud squealing at any speed.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
