Driveline rubbing the squel (forward gears only)?
jtstacy77
Hey guys I have an issue with my 06 avalanche 4wd. It is making a sound sorta like a brake pad rubbing on a warped rotor, when I initially begin moving. No sound in reverse just in forward, under power. Once I pull out at any speed it is more of a loud chirping sound, again no throttle no chirp, give it gas and it starts again. Tried it in reverse one more time and nothing. Also the sound does not change with braking, I have tried applying different braking pressures while still giving it gas and no change in the sound. It sounds like it is under the cab, but hard to tell when trying to diagnose driving down the road with my door open! Also I have noticed a smell like burning oil maybe grease outside the vehicle after an extended drive. Thanks for any help, I appreciate it!
Pull a 4 wheels and start inspecting. If you didn't mention a burning smell, I'd tell you to check your u-joints. What you describe can happen with them, I've had it happen to me. Noise under throttle. Nothing coasting. Nothing in reverse.
I appreciate the info. I got under the avalanche today and I don't feel any play in the ujoints. I did notice I could push up on the driveshaft and the shaft coming out of the back of the transfer case will move up and down about 1/4 to 1/2 an inch. Is this normal? If so I guess I will try replacing the u joints. Thanks again!
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
