My pickup would not start again this morning ?
Turn the Key and nothing (all the lights and radio work,the headlights work and don't  dim when i try to start the pickup)?? I't done this a few times. I keep trying and then all of a sudden it starts?? Any Ideas??
2000 gmc 5.3 4x4
Check that battery cables. I had a simmilar problem a year ago with my '95 Tahoe. The cables are doubled up and the cable closest to the battery powers everything but the starter and I had alot of corrosion between teh cables so the starter didn't get enough power to crank it over. Cleaned the cables and put in new bolts and it has been good ever since.
Not sure if GM still double up the cables on the "+" side but its worth a look.
Good luck getting it going.
