Advent question
hello, a friend of mine is looking at buying the Advent OGM1 nav unit off his uncle, apparently his uncle traded the truck in and had the unit removed but whoever removed it didnt take the GPS antenna and iPod hookup out of the truck when he did. Therefore if he buys the unit off his uncle he'll need these two chords so i was wondering if anyone knows where i can purchase these two from? I told him id ask on here since there seems to be allot of know how with these units on here and you guys are so helpful when it comes to stuff like this
[the unit is from a 2008 Chevrolet Silverado incase that matters]
Thanks!
Contact Walt at ADC Mobile. He will beable to get everything you need.
google ADC Mobile. u can contact him via email there or it gives you contact numbers as well.
