AP Xlerator suggestion?
I'm considering putting one of the Xlerator mufflers on my truck. I have a 98 GMC Sierra with a 5.7l 350 in it. Does anyone know anything about these mufflers? Any reviews or experience with them? Or does anyone have any suggestions on any other mufflers? I love the old muscle car sound, but I don't have old muscle car money.. I'm not fond of the raspy poppy noise that the glass packs give.
I wasn't sure what exhaust to go with on my truck, but my exhaust guy talked me into it. I had one put on my 2012 Sierra with the 5.3l about two months ago.. Sounds freaking awesome! very deep, no drone, just plain ol' good sounding exhaust. i'd put it against borla, corsa, magnaflow.. any of them anyday! I looked at Borla, corsa and magnaflow and i haven't regretted my gamble one bit. DO IT.
kstruckcountry, when you say Cherrybombs, do you mean cherrybomb glasspacks? I've thought about glass packs before but i'm not fond of the raspy, poopy noise after the rev down.
And offroadn11, do you have dual exhaust? or is it just a single muffler?
Yeah I had the Cherry Bomb glass packs on my 1990 when I first got it. I had them replaced with generic glass packs since the welds on the Cherry Bombs weren't very good and it was easier than trying to patch up the holes. The generic ones didn't have the bubbly softer sound of the Cherry Bombs. Neither setup droned (or maybe I couldn't hear it over the wind and tires). No cats either. My exhausts were run straight out the back so that probably helped. I'm a big fan of the longer Cherry Bombs on the 350's now since they were so much better than generic.
But I have a Magnaflow 22" on my 2006 and it's very mellow and sounds good. Even with a Magnaflow you'll get a pretty big burble on run down. Solution: Put it in gear before you give it gas. Sounds better that way and more importantly the gas actually gets used for something :lol:
Thank you guys for the input. My truck doesn't have dual exhaust.
I want a good, deep, throaty roar, should I just save up and go with duals?
And about the duals, would duals with two separate mufflers be better than a single pipe ran into a single in dual outlet?
I had true duals on my old pickup, but I was in high school in a small town, it's mandatory. :lol:
On my 2006 I stayed with one pipe all the way and I'm really happy with it. 2 mufflers will be quieter than one, but the Magnaflow muffler is pretty mellow so it's still not really loud. I think you would be happy with a single pipe, duals are mainly for looks I think.
Most people go with duals for Flowmasters or glasspacks.
So, I've come down to the decision of a flowmaster super 10 delta series, si/do. I know a lot of people say flowmasters are restrictive and they hurt performance, but considering I still have the stock muffler, and i'm not looking to add performance and i'm not worried about losing any cause I don't race my truck. haha. I just want a nice, aggressive sounding tone to make my truck actually sound like a truck.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
