Aftermarket wheels?
agallaher126
Does anyone know if the kmc xd125 wheels with the 18mm offset and the 5.71 backspacing with stock size 265/70/17's fit my 2012 1500 without rubbing? My truck still has all stock suspension. The website says they fit but I feel like with my luck I would buy them and then they wouldn't fit right.
On those tires you will be fine. I have a 20x8.5 with a +22 offset on 275/55R20 and I rub the plastic inner fender because my inner fender is destroyed and hangs down
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Cool thanks. If I got the bilstein 5100 leveling shocks would I be able to run 285's? I believe on the highest setting they raise the front end like 1.77 inches
Should work. Some people just run a 1-1.5" level. I run a 2.5" on my truck with the 275/55R20 and like the look
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
