iPhone 4 cradle
Im wanting to add a bracket to my dash that I can mount my iPhone 4 into so that I can use it hands free, or even use the GPS without having to hold it. I have searched on Google, but all the results are either for 07 and newer trucks, or completely off the wall and useless. So, I was wondering if anyone with an 800 has a dash mount for their smartphone. Im sure someone does.
Post up pics, descriptions, and where you bought it. Thanks.
Check out rokform.com. they have a pretty cool set up with the cases that they sell and mounts they have.. I have one on my galaxy s 3 and iPhone 5..
Sent from my SGH-T999 using Tapatalk 2
