Tire upgrade ideas??
clarkysilvy10
Hey everybody, I'm looking to put a 2.5 inch rough country leveling kit on my 2010 silverado and been looking around for the biggest tires I put on without any rubbing or cutting. I want to stick with an aggressive tire so a trail grappler or open country m/t just not 100% on which size will work the best and i want to stick with 18 inch rims, looking at xd spys. feel free to chime in on any opinions or knowledge you have, nothing is set and stone and I'm glad to hear any ideas! thanks!
No need for 2 of the same topic
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
