Electrical problem?
Zbyke
I have a 2009 GMC Sierra crew cab z71.
About two to three months ago my locks started unlocking and locking three to four times while I was driving. It would randomly do this, I could have a week or even longer where it wouldn't happen and then out of the blue they lock and unlock, three to four times while driving.
Then about a month ago, after parking and going into the store, I tried to remote start my truck (factory remote start) and it didn’t work. When I got into my truck I put the key in the ignition and turned and nothing, no power at all. I opened my hood looked around and didn’t see anything, closed it and it started back up.
Then randomly the stereo tuned on but no sound and my blinkers worked but there was no clicking sound.
About three days ago it has gotten even worse. My locks, while driving, unlocked and locked about 30 or more times. Each time it did that the acceleration wouldn't work, my truck was jumping up and down and I couldn't go more than maybe 10 miles an hour. When I pulled to the side of the road and tuned the truck off and back on, again there was no power just completely dead. I got out and opened the hood and as soon as I did my lights came back on and my hazards started to work (I pushed the hazards button right before getting out of my truck.
Any idea just what may be causing this?
Bad battery connection(s).
Bad/poor grounds.
Battery shorting internally or otherwise failing.
Bad/poor grounds.
Bad/poor grounds.
^^^^ The place to start.....
Had a similar problem in my 2000 sierra and it turned out the negative battery cable was just loose enough to vibrate around. Tightened it and fixed
Sent from my SGH-I927 using Tapatalk 2
Thanks for the replies, I will let ya'll know what I find out.
  • 1 month later...
Turned out it was a corroded positive wire that ended up touching the frame. Fixed it and its good now. (fixed back in April)
Glad it was ¢¢ and not $$!
Gotta watch for that stuff, it is hard on electrical parts and electronics!
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 483 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
