Greetings To You All!
JeffNwtn
Hi all;
I am a new member here for the very first time, and I do have a few questions:
1) any one here currently driving a 1995 S10/Blazer 4WD/A/T with a GM V-8 conversion? I really like my Blazer, and I am looking to (perhaps) do this conversion. Would the cost be too high? I could handle around 5-6$k for the conversion.
2) Can the Vortec 4.3L V6 be built and still pass smog ( I am in Southern California)?
3) If this can be HiPo'd, where should I start?( I have K&N FIPK II, HiFlo Cat/Muffler, Jacobs OmniPak, MSD 8MM Wires installed- i figure it is around 205-210 H.P?
4) can the AT be built for firmer/quicker response?
I really appreciate you all for taking your time to help me in any way possible!
Thank You
JeffNwtn
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
