Speakers work intermittently - probable cause? ('01 Suburban)
This issue is a recent development. Every now and then, my front drivers side speaker won't play at all. I thought maybe the wiring at the speaker was loose. But then a few days later, it would be playing fine and all 4 rear speakers won't be playing. This issue comes and goes and is incredibly hit or miss. I know it's not a speaker issue, so that leaves the radio/head unit or the amplifier.
I'm sure I'm not the only person to have had this happen. So, which is more likely the culprit? The radio itself, or the amplifier?
If you've checked all your connections, then I'd say radio or amp. Got an auto electronic shop nearby? Pick their brain.
Guess what?
You may find that it is a speaker issue. The speakers in my old 2003 S10 did this almost from day one, with both the factory and aftermarket radios. It was worst with the passenger's side dash/door speakers, though the driver's side door speaker would also cut out from time to time.
All of the offending speakers were replaced under warranty and the problem came back in time. Extremely cold or hot weather seemed to make the problem worse. Slapping the speaker grille (how low tech!) would often get them playing again.
The only speaker that didn't give trouble during most of the truck's life was the driver's side dash speaker. Just before I traded the truck, it started to only function if the weather was warm. (Sometimes, carefully playing with the wires going into the spider portion of the speaker would get it playing for a while.)
Both of the front door speakers in my 2007 Silverado Classic were dead, though one of them did start playing out of the blue one day. I sent them to someone who repairs speakers and he says it's a common problem with the wires going to the voice coil failing to make reliable contact.
Try turning your radio up very loud, or firmly rap the panel near a speaker when it isn't playing. See if it starts playing.
If you have an aftermarket radio installed, check your wiring connections especially if by some chance they are not soldered.
Tell me how you know its not a speaker issue
Sent from my Nokia 5190 using Tapatalk 2
It would seem strange to have 5 rear speakers work fine yesterday, but not work at all today, and then work fine again tomorrow. Litterally all 5 speakers. I could understand an issue with the voice coil wiring on one speaker... But five? It seems more logical that the problem would be with the signal not being sent from the receiver or amp.
It's always possible that the issue is with an amplifier. Did you try rapping on or around the speaker grilles to see if they would start playing? Did you try cranking the volume to see if that would make the speakers start working?
As I said previously, when I had my S10, three of the four speakers would not play under some conditions, and the defect was definitely in the speakers themselves.
A broken audio power amplifier tends to stay broken and if it's broken badly enough, it will blow fuses.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
