Removing Body Lift
  • Replies 66
Put the new rims and tires on and I honestly I like the look so much better than the 35's, I think it's the wheels that really did it. Also got my headers installed and that made a huge difference in performance. I'll get pictures ASAP
Alright I'll get some pictures, the wheels don't have the center caps on though because the lug nuts from the old wheels are too long. What size lug nuts are on these trucks?
I'm not sure the exact size, but mine have worked on 4 different sets of wheel without any problems. It seems like the ones you're using with the Monsters should work :dunno: .
Pictures or ban! :jester:
X2
Sent from my SGH-I927 using Tapatalk 2
They're comin I just don't want to put a picture up without center caps! And the ones from the monster were too long so I need to find some shorter ones for the center caps
Here's a quick pic for proof:)
Edit: just kidding can't upload on iPhone
Ban this mofo :jester:
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 509 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
