Tailgate Light Bar?
I want to buy a light bar and also noticed it is NOT plug and play, uses 4 pin.
Man I hate to cut wires. I guess the only real choice is that Curt plug above.
I had a light bar on for eight months, but then my mother told me it was acting weird while she was following me one day. After I checked it out, and couldn't fix it, I just ripped it off the truck. There are not a lot of them running around here, but most of the ones I do see, seem to have shorts and not function properly.
Long story short, had one, it went bad, removed it, like the truck better without it.
I had a Line-of-Fire on my 2004.5 Dodge from within two weeks of buying the truck (new in 2004), it had to be removed after it was crushed buy a Jeep Liberty that had been driven into me by an 18-wheeler...up to that point it had worked flawlessly, and that was at about 260k miles, last spring (right before I bought the Silverado). That truck (and the light bar) saw every state in the US at least once, and in every weather condition...never had an issue with an LED or the housing. The Dodge's had a secondary 4-way (in addition to the 7-way RV) tucked under the rear bumper, so that installation took less than ten minutes including mounting the thing.
If you get a good name unit, it should last a long time. Line-of-FIre was the first/original product, I actually had one of the first one's seen on the road around these parts, they were really new at that point.
Another option is what I just did...I drilled the piece below the tailgate:
Those are 3/4" LED...you drill a 13/16" hole, add a gromet, and push the light into place. You could do a whole string of them under there...and nothing to break off, and they could be replaced individually if one failed.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 420 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
