Tire "Feathering"
Gurrzt
Anyone out there experiencing this on their trucks or suv's?
I have not rotated my tires in 10k miles, however I believe it to be an alignment issue, relating to the "toe" setting".
I am running 285x45xR22 on a high quality 22x9.5 rims (+34mm offset).
Any comments would be greatly appreciated, thanks in advance.
Feathering on inside or outside? How bad? Pictures are almost a necessity for a topic like this. 10 K with no rotate is definitely a problem. Also did you have alignment done when switching wheels and tires? If not I would check front steering and suspension and start with alignment.
Sorry for the lack of information, the "feathering" was light on the outside part of the tread.
I had the vehicles tires rebalanced and "cross rotated" (non directional)@ the place of purchase, and had the vehicle re aligned.
The alignment was dead on (I had previously purchased a 2 year alignment plan), with no toe problems. It was a 4 wheel alignment so I know the rear wheels are straight to the front.
After total examination of the front end and shocks (all was good) I was told that the rims on the vehicle (I purchased at the same shop as the tires)were a different offset than the stock (+34 vice +31) and in their opinion was enough to change telemetry of the suspension. They suggested I return in 5k miles to have the tires re rotated and rebalanced (a free service).
I do not know if their analysis is correct, or they are blowing smoke up my rear end, however I am going to go have the vehicles tires rotated @ 5k.
I have my alignment checked and corrected every 4 months (with the package I purchased).
I think they're give you some BS about the wheel offset causing feathering, and I rotate at every oil change just to be safe. I know that may be overkill, however it's an inexpensive way to prolong the life of my tires.
So then you think it is more of a rotational issue?
I know mine got that way from not rotating them properly, but I would guess that worn front end parts and bad alignment could cause it also, I'm definitely no mechanic though man.
Yes I agree, and my vehicle is a 2013 model, so upon inspection all the front end bushings and the shocks are good.
I am going to start a rigid tire rotation every 5k miles, and have the vehicle realigned (upon the rotation).
I too am by no means an expert on anything mechanical.
Thank you so much for the input, much appreciated.
    Aries68
    Aries68
  • Who's Online   2 Members, 0 Anonymous, 436 Guests (See full list)
