Leaf Spring Block Squeak
I recently put some 3" Zone Offroad blocks on my rear axles. Since having them on, they rub against the leaf spring and make a creak/squeaking sound every time I accelerate or brake hard. I've sprayed silicone lube between the blocks and leaf springs a couple of times and that helps for a day or two but then the noise comes back. I'm embarrassed by the noise and I'm contemplating putting the stock blocks back on. What are you guys using/doing to stop the noise? Also, is this harmful or potentially damaging to my truck?
All the way until they wouldn't tighten any more using a cheater bar. I've since retightened them every week with the exception of the last 2 weeks since they won't tighten any more.
and replace the u-bolts and nuts and torque to the recommended torque
,you have over torqued yours and are risking the public that share roads with you
when the ubolts break ,you will be sued beyond anything you can imagine
i wouldnt drive it ,,,im asking you not to
I got my hands dirty today and figured out what it was. The surface on the axle where the block sits is not perfectly flat; it's actually slightly round. The replacement blocks are flat, and they rock around on the axle as the center of pressure shifts on the leaf springs. The factory blocks (see attached) have a notch in them to get around this situation.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 461 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
