Only one E-fan is operating
Chris
It is 105 here. I was towing 6000 lbs and A/C on high. Only one fan working. The driver side fan sat motionless. Both were working last week.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Start simple. remove the connector(s) where applicable and check for any abnormalities in the plug or in the wiring.
Relay plugs melted a bit. changed 2 swapped 2 relays and swapped the 2 fuses and both work. No new parts, just changed positions
I wish every repair was that simple! :cheers:
I know, but one of the plugs for the relays is melting so I may have to get a new harness
I'm going to when this goes. Got a p/n?
  • 4 weeks later...
Chris, did you get around to a fix or replacing your harness yet? Did your truck come with e-fans or did you do the Blackbear aftermarket mod? I have 2 new harnesses from LS1fans.com leftover from my '02 and the Blackbear mod. If you can use one, let me know and I'll send it to you.
Ron from LS1fans.com got me one out in express mail to warranty it out
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
    blueskytruc
    blueskytruc
  • Who's Online   4 Members, 0 Anonymous, 648 Guests (See full list)
