Hey there
CustomChrome
Yup another newbie. But anyway, I'm running a mint 89 1500 with a 350hp GM 350 crate motor, Auto w/Shift kit, 3:73 rear L/S. I would post a pic but I'm not sure how. Right now it's two tone red and burgendy. Soon as I get cought up here in the shop I will give it a fresh look. It should be wild when finished. Like I said before it's mint now but I figure 40 hours in the paint booth and it will be "Too Sweet" as my son would say. Also looking to do a 3/4 drop, shaved doors, frenched everything, just to start. But I live eat and sleep Hot Rods! When I get sick it's usually Hot Rod Feaver!!! LOL.
I hope to get to know some new friends here.
And I'm looking for some crusiers to hang with.
Later!! For now. CC
Thanks everyone! Ya it's a real sweet truck. So sweet it made me change sides. The last owner was family, and I was after it for 4 years. When uncle Don died I was the only person who didn't ask if I could have it. I was the only one who offered cash! And home it came. It was garage kept and never seen snow untill last year! But driving it in the snow is too tricky! So it stays in the garage unless the roads are clear and dry. But I'm glad I found this place. I'm hoping some of you can help me make it what I dream it will be.
Later C.C.
    • *Your
