99-06 Cognito pitman/idler arm support kit, anyone use it?
Just seeing if anyone has this Cognito support kit for their pitman and idler arms. Its suppose to reduce/eliminate the front and rear movement of the arms so it stiffens up your steering quite a bit. I haven't seen many reviews online, so figured I'd ask here
My steering has a lot of play in the wheel, I believe too much for a rebuilt gear box, so just trying to tighten it up without replacing the box, because govtech4 said its probably not the box.
I already have a steering stabilizer, which helps a little bit
  • 3 weeks later...
Yep, for 2500hd tho. That and fab tech HD tie rods, it's awesome. Truck can handle 15 psi launches on 35's :)
You'll like it, it's worth the money. I also have billet centre link
Yeah since no one replied I went ahead and bought the kit based off other reviews online. Definitely took a lot of play out of the wheel for sure. But it still pulls right a little bit because when I got my last alignment done they could only get it close but not dead on because all adjust.cents were basically maxed out. Hopefully I can get it done better this time with this lift
Support brackets for both idler and pitman arms, heim joints for where each of them connect to the center link, four nuts (2 each) for heim joints, lock tite, and then sleeved nuts, not sure of the proper name for them but that is basically the idea on them. Check it out. Kinda pricey but if your tired of loose steering, this will definently take out quite a bit of play. Makes it nicer for me with 35's on the highway
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 575 Guests (See full list)
