6.0 Towing
We took my friends 6.0 Crew Cab, Auto, 4.10's on a snowmobile trip towing between 2000-2500 lbs. When we come up on a hill and he kicked it down it had like a stutter around 3900 and it didn't wanna go over 70, I can't imagine this to be normal, anyone know if it is or may there be a problem ?
I've had my 6.0L cranking over 5K RPMS and 70 + MPH in second gear with a 8000 lb load behind it just by putting my foot to it!!!  And she was pulling strong up a 1/2 mile hill!!!
Something doesn't seem quite right with your buddies truck!!!
I've got to agree with Shaners.  I've got a slightly lighter load but, I've been over 4K rpm over 70 mph in 2nd uphill in PA and pulled great.
I have a 1500HD, 6.0 and pull a 9500# car hauler. Have never experienced this problem. Sounds like torque converter or ignition problem. :cheers:
I have the 6.0l with 4.10 gears pulling a 4 place enclosed snowmobile trailer and never had the problem your talking about. I have hit some pretty good hills heading into the White Mountains.
We take dads 6.0,cc,auto, 4.10's pulling an aluminum 4 place loaded to Michigan and never have any problems. I think the last trip it only shifted down to 3rd twice the whole trip. We run 75-80 most of the time. No problems, something must be wrong with yours.
I've pulled a gooseneck with a load on it pushing the total weight above 15,000 on a 6.0 and the Engine took it like a champ.  But I have a stick and I shifted at 4500rpms.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
