No spark #7
Hi everyone, first post here hoping you guys can help me out.
I have no spark on # 7. have put new plugs, wires and a coil on that cyl but still no spark when testing with a timing light and I get a random misfire code. Is there a common problem that would cause this issue? I see no problem with the wiring. Thanks for any responses.
You didn't even state what type of truck, engine, etc. If you want help you need to provide the basics at least. List the code as well....
Random Misfire: 2 or more cylinders are bad
low fuel pressure
vacuum leak
Bad battery
Bad spark plugs/wires
So now you know a little more on random misfires.... it is not just one cylinder so you have more to look for !!!!!!
why are you focused on #7 then ,?
you have access to a scanner ?
#7 has little to no spark checking with a timing light. All others are firing fine. When I rev the truck up the light might flash 1-6 times but then at an idle it drops off to nothing. Ohm testing the wire and it matches the other wires. Swapping the coil and wire with another cyl and the miss stays at #7. Also after rev'ing it just starts smoking out both tail pipes almost like a blown head gasket but the smoke doesn't smell sweet like antifreeze and is white to light blue. I should rescan, I cleared the codes and after starting up the cel came back on and I just assumed it was for the random misfire.
Fuel pressure is at a constant 60psi. Still struggling to find out why the P0300 and the all but dead # 7 coil.
If you swap out coils and get no spark then you most likely have a wiring problem. I'd start tracing the wires through the connectors and make sure you don't have a wire somewhere that got rubbed, pinched, or grounded by accident. I can't believe the computer is not firing one cylinder, so I am making the assumption that your issue is in the wire harness/connectors.
Okay thanks, I see the coil harness plugs into the main harness between the center coils. Think I'll disconnect that plug and check for continuity between that plug and the # 7 coil. That should tell me if it's in the coil harness or the engine harness.
That was easy enough, the coil harness checks out. Does anyone has a wiring schematics for the ECM? There are three main plugs, it would be very helpful to know which plug and pins I should be looking at. Thanks in advance.
While you are disconnecting the various connectors, look at them closely for any signs of corrosion or a bent pin or something out of place. With the truck running, wiggle the wires at various connectors along the line and see if you start getting the spark.
I know you checked with your tester, but as you have things unplugged, you may get an ok reading. However, once reassembled, the pin may move slightly causing an intermittent connection.
This is how I have found several electrical problems on a motorcycle I own. You can trace the wiring and if it all seems to check out then you start wiggling things and looking to see if there is any change. Found connector issues. I've also done this with an old S-10 I had. Was constantly getting EGR codes even with new sensors and EGR. Eventually the truck was running and we started moving the harness around. the problem went away and we found the harness had rubbed against a manifold and caused one wire to ground against the cylinder head. Anyway, check every bit of wire you can.
Yeah I did inspect the plug-ins, and have been tugging on the engine harness and connectors with the engine running but nothing changes. Next to the PCM the wrap around the wires is all coming apart/crumbling, but looking underneath I don't see any scuffed wires.
    JohnRoy
    JohnRoy
  • Who's Online   4 Members, 0 Anonymous, 671 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
