2014 Bed Hold Downs
I've noticed on the 14' CC Silvy television commercials that there's four upper and four lower bed hold downs. I ordered my LT Z71 in July, it was built in early August. I only have the four lower ones. Was this an option that I missed or something that GM started including in the latest built trucks?
lovemytruck, Its an option for the upper 4 tie downs installed by dealer for $60. I saw them advertised on ebay.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
