2008 Gauge cluster question
Hi all,
for some reason a few years ago my 08 Silverado gauge cluster started cracking. It has progressively gotten worse as all the faces are now spider webbed. I'd like to replace the cluster but was curious if a different cluster would register odometer miles from the donor vehicle, or would the mileage be stored in my vehicle computer?
Mileage is stored in the cluster. The new cluster will need to be programmed to your VIN, iirc
You can find someone in your area first who can reprogram the odometer to read what your vehicle has.
It is not stored any place else.
You can reprogram the odometer out of the vehicle.
At the dealer they have the car and the new cluster they have to reset to original milage.
I know they make gauge face kits that you put in by removing the front of the gauge cluster. That being said you can probably just replace the clear lens off of a donor and save yourself some work and money. :thumbs:
I was actually thinking the very same thing regarding swapping the lens over from the donor...maybe even put some gauge covers on for something different. Thanks everyone for the replies.
Anybody have an idea as to why the thing cracked? Perhaps when I remove the old one something will be obvious.
-Matt
is it the lens or the gauge face got a pic? If its either they are simple to replace. the lens just snaps off and if it's the gauge face you just have to pull the needles and lay it down.
lens: http://www.ebay.com/itm/07-13-NEW-SILVERADO-TAHOE-SUBURBAN-SPEEDOMETER-CLUSTER-CLEAR-PLASTIC-LENS-ONLY-/370900902239?pt=Motors_Car_Truck_Parts_Accessories&hash=item565b6aa15f&vxp=mtr
lf it's the face you can go aftermarket or If you want stock I have an extra one out in the shop just let me know
    appletrav
    appletrav
  • Who's Online   1 Member, 1 Anonymous, 325 Guests (See full list)
