Air in brake lines
Ok guys I replace front and rear
pads/shoes. Now I have no brakes. I have manual bleed the brakes, two person method
and one person method. I think I have air in the ABS. I got a Autel DS708 Automotive Diagnostic and Analysis System http://www.amazon.com/Autel-Automotive-Diagnostic-Analysis-System/dp/B008XN7NUG
That will allow me the bleed the abs but I still have no brakes. The front looks like both sides have air in them
and the back look good. Anyone ever use the DS708? What am I doing wrong?
2007 Silverado 1500
Because I have no brakes. I'll I did was change the pads, like I’ve done many times before. This is the second set up pads for this truck. I did not do anything different. I did not open any lines to let air in. The back brakes with stop the tires when on the lift but not the front.
Was this a problem before? Why do you suspect air got in the system if you did not open the lines up?
No I just had a noise coming from the front driver side tire. Once on the lift I found the pads were very close to metal to metal. So I replaced them. Everything was working fine just had a little noise from the pads. The truck has about 81,000 miles. As I bleed the rear brakes the fluid
comes out nice with no air or bubbles but a nice solid flow. Now the front is different their lot of air it in the system both size are about the same. If the brake pressure modulator valve has bad from pushing the calibers back in for the new pads would it show a abs light or something. As of now I have no code on the scanner.
You wanna start bleeding at passenger rear tire, then left rear then right front then left front. Put a tube over the valve an place in clear bottle with brake fluid in it so you can watch for no air bubbles. You will need someone to pump the brakes while you do this.
Well the dealership told me for 50.00 dollars they would finish the bleeding of the brakes. Really can’t pass a deal like that but I can’t drive it there snow and ice on ground now. It’s about a 10 mile drive. They will most likely say I need more things replaced to make more money. I will try
the bottle thing next.
Well I gravity bleed the brakes first with the bottle that did not work. I also pump the brake with the bottle, hose in bottle, in brake fluid that did not work. So I will be taken it to Kippelmier Chevrolet.
what is the breakdown of the $500 ? ,parts labour etc
btw,videos dont make you a mechanic ,,,you should really have a garage do this for you for safety sake not financial sake ,,,,,,
He did not give me a breakdown just a total.
I believe anyone that wants to do their own work can. I am not a mechanic but I have not seen anything they can do that I can’t. I feel the only difference is a mechanic has the right tools to do the job faster.
I test drove it today about 30 miles and all is good.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
