Help!
Guest Friz
I was supposed to tape the shootout for General Lee and completely forgot about it. :D
He is gonna friggin' KILL ME!!! :lol:
Did anyone tape it, by chance?
Friz check your PM! Don't worry, your computer won't blow up. :lol:
Take it easy on yourself Dan, my Grandfather has forgotten to tape things for me many of times, but he's still living (On life-support mind you, but, still living :D )
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,349 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
