head gasket how long
95z71performer
How long does it take for head gasket replacement on a 95 5.7 tbi I'm going to need to do it this weekend and bought all of the gaskets that are going to be taken off so they will all be new just figure to ask here for a time range cause someone must have had to do it before
Since you are asking, it must mean you have never done this job. It would take an experienced person with the correct tools and replacement parts somewhere between 4 and 8 hours. But, if the heads need resurfacing (ask yourself why did the head gasket go), and you started this job on a Saturday morning, you may not get the heads back from a machine shop till Monday.
If something goes wrong, like broken exhaust manifold bolts, you can add hours to the job.
I am not trying to dissuade you from doing this, just trying to make sure you go in with eyes open.
Something you may want to also look at is how many miles on the engine, and has the timing chain ever been changed. The two jobs are not really connected, other than the draining of the cooling system, but, if there are lots of miles on the engine, it is not that much more work. You have the tools out already, It would add a couple of hours, assuming you have or can get the puller for the balancer.
what doug said X 100
if you are thinking of time in the back of your head while doing this (not a first time) job ,you are in for a bad time ,,,,
consider an engine replacement if milage is way up there and you are gonna keep the truck awhile
Looking at your profile it looks like you did not buy the truck new. What do you know about the history of the truck? If it is not burning oil, or knocking, and compression is fairly equal across all cylinders, then the engine is likely still good.
You have not said why it needs head gaskets. This is actually one of the most important pieces of information needed. If the head gasket is blown between two cylinders, get the heads surface checked, and resurfaced if there is any warpage. One benefit of resurfacing is that they clean the face of the head for you. If head gasket was leaking antifreeze, you need to look at the spot where the gasket failed. If there is any mark in the surface of the head at that spot, resurface both heads.
While you have the heads off, see if the engine has roller lifters. Pretty sure it should be roller lifters. Since you likely do not have the complete history of the engine, it may not even be the original engine in the truck.
If it was my engine, I would check compression, check oil pressure with mechanical gauge, check the play in timing chain, and do a good inspection of all the spark plug condition. Look for deposits on the spark plug, paying attention to the colour. After knowing what the condition of the entire engine is, you can then make a more informed decision regarding what would be best.
One last thing, if you low on funds, and need to use the truck for work/school, do the checks above before you start tearing it apart. No sense starting something that there is no way you can complete it.
I have antifreeze in my oil and i also had my thermostat stick (i now have a new one) and overheat the truck and no its not the original engine the previous owner swapped it from another 95 and it also has headers and a throttle body spacer but I still have yet to check plugs cause of the headers being there and I don't wanna deal with those right now cause I'd sooner do the wires plugs cap and rotor while i'm at it
Isn't 95 right around the time the engines switched to Vortec?
If you have coolant in the oil, then you can be sure that will not be able to complete this job in one day. Heads will have to go out to be checked for cracks and if ok, at least a resurface.
If you do not know how long the coolant has been in the oil you will want to pull the oil pan and check rod and main bearings. I have seen coolant in the oil attack the bearing material, creating pits in the first layer of bearing. You will need to sit down and consider the costs involved in repairing this unknown engine. Since the engine was changed, how sure are you it is still a 350? You should also consider having bungs welded into the exhaust pipes to get the oxygen sensors back into the system. No o2 sensors mean no closed loop operation. Not good for drivability either.
If it were me, I would find out how much money I had available, from that look at what else the truck needs to keep it drivable (forget any mods like big wheels and tires, raising the truck, cosmetic crap). Then look at options for engine.. The engine options are the last parts to consider. Reason for this is simply because getting a monster price engine, then having nothing left to get the truck back on the road is not something you want to happen.
From the sounds of what you have described, I have a feeling the heads are toast. One thing I would not do is purchase a set of aftermarket heads and installing them on this engine, without having inspected crank and bearings. And also take a good look at cylinder walls once heads are off. Look for scratches, scoring, and pay attention to the very top of cylinder wall and look at the "lip". It is a good indicator of overall condition and wear on the core of the engine. I think you will find that your other issues of idle quality and sound will be resolved after a proper job is done on the main engine issue.
It was three gaskets the right side head gasket and both intake gaskets were also bad and it's getting finished up tomorrow everything went smooth and the engine itself was perfectly clean
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,246 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
