2014 Silverado LTZ 2WD, need measurment
Can someone with a 2014 Silverado LTZ 2WD stock w/ 20" wheels measure from the bottom of the wheel/rim edge to the top of fender? Trying to figure out how much exactly my 2" leveling shackles lowered my truck. Your help would be greatly appreciated!!
From your pic it looks like your rear end is a hair higher. Maybe others have removed the stock block that is in there as well when adding a lowering kit.
The rear is 3/4" higher than the front if measured in the way i posted in the OP. The rear block someone measured on here is 1.25" thick. I'm thinking of replacing the factory block with one that's 3/4" thinner so a 1/2" block to try to get it closer to level. Some like it some say level it perfectly. I'm on the fence at the moment, not sure if I'm ok with it or if I should perfect it.
I think it looks good right now but I'm on the side that says get it as level as you can. Great looking truck by the way!
Thanks man, the OCD in me is making me want to tweak it so it's perfectly level!
  • 1 month later...
Did you do this yet? It so, did it work. I'm in the same boat after the 2" lowering shackle install.
Did you do this yet? It so, did it work. I'm in the same boat after the 2" lowering shackle install. Sent from my iPad using Tapatalk
I have the blocks sitting at home, just need time to swap them out.
Let me know when you're finished and if it's perfect :) Tapatalk via iPhone 5s
I'm currently in an apartment and trying to get the truck over to the suspension shop this week. Just waiting on a call back lol.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 483 Guests (See full list)
