I am new to the group. Admittedly, I don't have a GM truck, I do have a 98 vortex V6 with a 4L60E swapped into an 83 Jeep Scrambler. The motor has been fantastic and trouble free for many years now. My trouble has been with the transmission. Some details on the Jeep. It had 33" tires, 4" lift kit and 4.56 gears.
I drove it like this for some time when the trans started to overheat when I drove on the highway. In time, it started doing this regularly. Always shifted fine. it finally died, had it rebuilt but died soon after that, assuming a poor job with the rebuild. Swapped in a new transmission. Lasted a while with no symptoms, now it's overheating again. Had a cooler put on. Cheap cooler died, replaced that. Still overheating. It is currently having trouble shifting into o/d. That's a new symptom. I think it's slipping some now too.
I recently put 35" tires on but that didn't change anything. The symptoms were there before the tires. The gearing is appropriate for the tires. Not sure about the motor though. One mechanic is saying the gearing is to high, I'm thinking it's something else.
Any advice would be greatly appreciated. It's looking like this transmission is getting ready to go.
Thanks.
Scott
The 4l60 is a pretty weak trans..especially if your loading it down with tires and off-roading. Rather then keep putting a factory one in, go to a reputable trans shop who knows the weak points on it and have him build you a built up 4l60
Thanks. I'm thinking of going with a 4L80E. Beefier to start with and should be enough with some mods to it.
ya know its not a simple swap right ?
Yea, I know. I've been thinking about that too. The adaptor to the transfer case is over $530 Now I'm leaning on doing a few upgrades to the current trans. Suggestions on what to beef up on the 4L60E?
cant help ya there ,,,im sure there are perf trans out there to buy or sites that can help
Beast sun shell, 5 pinion planetaries, high energy band and clutch packs..just to name a few of the basic upgrades. Plan to drop at least $2000 on a complete rebuild.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
