Scanner Help?
Could anyone recommend a scanner for my gmc that would do for example a crank position sensor relearn and other usefull functions.
I have a read only and clear code scanner but want to upgrade. Thanks
Most advanced scanners that will do things like a crank relearn will likely be close to if not well over a thousand dollars.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
