Will 275/65/R20's Rub
strickland604
I want to know if anyone knows if I can put a set of 275/65/R20's on a 2014 GMC Sierra with a 2" level/lift with out them rubbing.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
