2014 HD Availability
Any one know how long the 2014 2500HD GMC will be available to order/buy before everything is switched to the 2015 version?
Thinking I may order one and I am sure the rebates will be better on the 2014.
Thanks
Thanks
They will probably be available for a few months after the new body style comes out in the spring.. But the selection will be limited. I bought a 14 HD and got a killer deal on it
So can you elaborate on what a killer deal is? Is 10 grand off sticker realistic?
Yes I will elaborate what a killer deal is. I got over 10k off sticker when I purchased a 14 diesel hd and that was a few months ago. It all depends on the dealer though. All dealers are different. From my experiences I have found that dealers who have a larger inventory of trucks are more willing to give a better deal
I bought a 2014 3500HD end of 2013. Got a great deal and got a snowplow[ 1000 discount] with business choice. On my last truck I got a free sprayon bedliner with business choice. plowking
Thanks
'15's are already able to be ordered, so you will be limited to what is still on the dealer lots for the '14's.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
