95 Silverado Radiator
My brother needs a radiator. He has codes KNP and KC4. It is a regular cab C1500 Silverado with the L05 350 and M30 4L60E. Is there something I need to look for? I see 28" and 34" radiators on Rock Auto. How do I know which is correct. I do not have the truck close to where I can go out and measure
My 95 rcsb has a 41". I have the 350 with the 4l60E
I'll remeasure in the morning.... it's pouring rain rign now.
The 41 is probably overall. The core sizes I have found are 28 and 34. My brother thinks it is a 34 but he is 18 and just got the truck. I just know I have to get him a new one
Sent from my SM-N900V using Tapatalk
Thanks. I know his has Internal and aux trans cooler and has the internal radiator engine oil cooler
On Rock Auto they list two Spectra Premium(which we sell where I work)radiators:p/n CU1693 & CU624(this being heavy duty cooling),both have connections for A/T & engine oil cooler.
We cater to repair shops & Dealerships,but,also sell to the public.Call our Bakersfield warehouse,they may be able to help you....
Fast Undercar Bakersfield spacer.gif 661-631-9000 133 V Street
Bakersfield, CA 93304 spacer.gif Fax: 661-634-9000
[email protected]
Outer is 41 x 18
Inner is 34 x 18 ish.. it's still raining so it was a little rough getting a tape down the front of my rig.
I have a universal design and had to plug a couple extra holes on the passenger side. Mine also has the 2 trans lines that connect, and I have an external smaller radiator.
Total
2 main water lines
2 metal trans lines on the pass side
Ok. Thanks. 90% of my knowledge is on the 99-07. Mine came with a 28" and I put a 34" in. I was thinking the same for thw 95
A difference in the HD radiator?
I asked at work...
These are Spectra radiators:
Normal Duty:34x17-1/4 x 1-1/4 p/n CU1693
HD:34-1/16 x 17-1/4 x 2-3/16 p/n CU624
Both have engine oil coolers & the HD is about 1'' thicker.The HD is $30-$40 more than the Normal Duty.
