UnderCover Swing Case
14SLTZ71
MotoMedic did a great job doing a detailed review. I have the driver side SwingCase installed on mine. I haven't had any of the problems that he expressed, it has worked flawless since I got it. Since the mounting screws are self tapping, I would be careful not to over tighten. I didn't weigh my contents but I would guess I'm closer to the lighter side that MotoMedic recommended. My truck is lifted so having the swing out feature really makes getting to my cargo easy without having to jump up in the bed. Cool product!
