Lock Ma, no HANDleS
Matthew4:19
The plates are machined from stanless steel, and backed with white lexan. They are back lit and wired together with the running lights, and there is an LED mounted behind that flashes when the alarm is armed. It is still a work in pregress.
I use the auxilary outputs of my alarm to activate heavy duty solenoids in the doors. I don't have any locks to slim jim or pick and in fact, don't even have inside door handles. When I finaly get around to finishing, the tail gate and wheathergard truck box will all open the same way. It already read has automated windows that are controled by the alarm and will have remote autostart. Thanx for your interest.
I did that on my last truck, Toyota. This time I wanted someting I could return to stock if I sell it. I took my original handles to the machinest and he built these to use the factory mounting holes and even angle the one post just like the handles had been. More than that I wanted to get the Word out.
Regarding tripple post, this post fit into every board I posted it to. light duty 2500 and the truck is, pictures and there are, appearence and that's what it is. Thanx for watching the boards for off topic posts.
I have no problem with the religion aspect at all personally  but there is gonna be lots of idiots out there that will, and most of them are stupid enough to mess with you ride because of it.
Man, if someone messes with that because of what it says, I feel sorry for what them where they're going.
Yes I was aware of the possibility of people vandalizing my truck because of the message even before, and I decided it was worth the risk. If someone messes with my truck there fate would be the same as someone who doesn't mess with my truck. They can be forgiven just as I am and "Those forgiven much, love much".
The passenger side also has Jesus. My goal for the tail gate handle will be three cut outs, a heart in red, a cross in white and a "?" mark in blue. I think from a distance it will look patriotic(which I am) and that may get people to look closer.
The heart is for the love of God, cross is for the sacrifice made and the "?" is for those who may have questions. If this does not look like I hope I will go back to my original idea of one cross in the center with two smaller crosses on either side. Significant of the two thieve's who were hung with Son of God. The theive's represent the world, one accepted His sacrifice and one denied Him. Please don't hesitate with any questions.
Not really big on the religion aspect of them, but hey your ride your rules. Either way though they look great, something different in a world of similarities. Of course after seeing this, I'm sure alot of people will copy your idea. A Chevy bow-tie, or dodge ram head (or w/e) would look great on something like that as well. :thumb:
  • 3 weeks later...
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
