Ran over a Parking Stop (curb)
Today driving through a parking lot I ran right over (right front, right rear wheel) a parking stop. You know, one of those semi-hexagonal concrete block things. I was going about 25 mph or so. No noticeable drivability damage...do we think it's okay? How easy is it to kill an alignment on these trucks?
A speed bump at 25 is one thing, but a "parking stop"? Those things are about 6" tall and not tapered like a speed bump and they are designed to STOP you, not slow you down. I would definitely be worried, but I wouldn't automatically take it in for an alignment unless I noticed a problem. I would definitely want to crawl under it and check it over visually. And I would also continue to monitor for excessive or abnormal tire wear. If I noticed anything that concerned me, then I would take it in. That must have been a pretty good shock. Did you hit your head on the ceiling? Did look around to see if anyone saw you do it?
I got cut off, and ran up a curb about the same size, at about the same speed.....bent the rear frame.
Yeah, I'm going to crawl under it this weekend. It was actually less jarring than you would think. Startled the mess out of me though! I might run it up to a decent shop nearby tomorrow to get the ball joints looked at. Talk about embarrassed...
Better to get it checked before chewing up the tires. In my case, I saw the guy coming, and drove up the curbing....didn't think it hit that hard at all, but they could barely get the truck in alignment.....that's when I brought it to a frame shop with Lasers and they found it bent.....total cost to get-r- done was $1,500
Had it checked out on Friday by a good local shop. All was well. As was eluded to, it was a good peace of mind thing if nothing else. Nice to know the truck could handle it!
Yah, your wifes Impala might not have fared so well.
I wouldnt worry too much, I cant tell you how many times I have bounced off the ceiling of these trucks doing dumb stuff, they take ALOT to break, engineered well IMO. Been a couple feet off the ground at 40 MPH and landed on the front wheels mainly a time or two (bad for stuff, I know) but broke nothing. When stuff does break it gets some nice upgrades tho :) It's a truck after all, you didn't pay 35K for a Prius!!!! Any other good stories?
Good news. When I hit mine, it was like "pulling off the side of the road"....just at 25-30mph, and over a 6 inch curbing.....wasn't what I would consider a hard hit by any means, at least not enough to bend the frame. Maybe mine was bent from the get go, but when the truck was on the frame machine, you can actually see where it was bent....the frame shop even compared the area of the bend with a new truck from the dealership (they work hand in hand).
Lateral force versus vertical force, and how much of each it's designed to take. Start from the tires and think up.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
