265/65/18 aggressive tires ?
nibael
An E-rated tire is for 1-ton trucks and it's way overkill for a 1500 but it won't hurt anything. They'll be more durable but weigh more and are stiffer so fuel economy and ride may suffer.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 240 Guests (See full list)
