Truck feels like ts in 4 x4 all the time
2000 chevy four wheel drive acts like its in four wheel drive when I turn on asphalt it grabs really hard on driver side and will leave black marks, I just had an alignment done but I did change out the torsion bars before the alignment just curious if something may have pulled apart, I can't notice anything. Thanks in advancee
imo ,ya shouldve saved your money ,,,i cant believe ya changed the torsion bars ,,,,,just another guy that comes here after blowing money and looking for divine intervention ,,,,
ya take it to a shop imho ,,,,internet fixes nothing
could be 5 things ,,,ya want a list ?
Why not change the torsion bars when there bad, what is the point of this forum then. For your information I paid $40 for a set of good bars that accually held up the front end, I change idler arms pitman arm inner and outer ties and ball joints, before I got it aligned and yes they were bad. Tell me then what's the point of this forum then ?
And yes give me a list that's what I asked for isn't it?
why not try a front diff actuator to start ooorrrrr have a shop look into it ,,,,,it could be the switch on the t case ,,,,it could be the t case ,it could the front diff ,,,,it could be some wiring ,,,its 14 yrs old dude ,,,it could be 50 things
good luck
First off I ain't no dude
It's not the t case I disconnected front drivline still does it, is it possible that something got over extended like the cv axles when I changed the torsion bars.
And I ain't taken it to a shop.
ok dudette ,relax
no ,you cant over extend anything when the torsion bars are replaced ,,
good luck ,im out
It would be possible for that washer to fall of the passenger side axle in the housing I have seen that happen but usually it wouldn't go into four wheel drive.
when the truck is in 2wd, the driveshaft to the front should spin freely when in park, if not, you are not shifting the case out of 4x4. Try it and post back.
I got underneath and driveline spins freely, the passenger side of the front end right where the cv bolts on has way more play than the driver side, I can pull the axle in the housing out far enough that I can see where the seal rides can't do that on the driver side. Wandering if something is wrong with the axle inside the housing..
Ya that shaft should only move in or out less than 1/16 inch. The circlip inside the diff could be broken. Kind of a bear to get at, gotta drop the front diff. You will need to measure the amount of play. Sometimes those just get sloppy and it never has any ill effect.
I am going to tear into this tomorrow and see.
ya dont have to drop the whole front diff to loose the right side axle shaft tube ,,,just pry the pumkin right side down slightly from behind while reinstalling axle shaft/tube assy,,,its hard to explain but there is a casting that pokes out like a small round pipe(rear right side of diff pumkin housing near tube mount flange) ,,,if ya put a small pry bar on top of the small tube from behind and lift up using the small xmember as the fulcrum the diff right side will drop down pivoting on its mounts ,,tube slides on nicely ,tighten bolts at that time ,release and pry whole assy onto the right tube mount studs ,,the motor mount is a good place to put the pry bar ,,,,you'll see what i mean ,
drain diff before reassembly
I did this once on a 1994 chevy years ago I remember it wasn't too tuff but I remember a collar type thing that I accidentally put back on backwards, thanks govtech4
    • https://www.msn.com/en-us/autos/news/fuel-economy-stickers-don-t-tell-the-whole-story-aaa-data-reveals-why/ar-AA26ocHk?ocid=winp2fptaskbarhover&cvid=6a4122ea3dae47e5b8dfbed5d4fd3d55&cvpid=648f6b4fc2fa4eddb4c12893aeb957ed&ei=59
    • What’s missing in all this is patience and investment in the future. Buy a 170K starter home. Ten years later sell it invest in a more expensive home. Eventually you’ll have a 600K home and pay starter home payments. Buy a starter car. Maintain it well. Save the payments after it’s payed for then buy an expensive car if you desire. Buy a tumbler make your own coffee, pack your lunch. Cook your own dinner. Most importantly take care of your car.
    • People mislead themselves. Statistics are highly useful indicators.   Here's the tie-in to this thread. If an oil sample tests shows a wear indicator of 7 using cheaper ACDelco oil, and a wear indicator of 2 (lower = less wear) using a particular brand of Mobil oil, and wear has a linear relationship with engine lifespan, anyone could assume that Mobil is reducing wear by more than 50% (let's just say a 200% reduction for you red state people trying hard to do math) which leads to increasing engine life by 2x. Perhaps, in a vacuum, by itself, when dreamed by AI.   Yeah?! That's what the statistic is saying, isn't it?   No, it isn't. It didn't come out and say engine life is doubled. That's a very bad assumption, and a case of severe myopia by assuming something potentially untrue about the only data point in focus.   Average cost of a new car is 50k. You bet it is.   The median cost of a new car is more like 35k. Expensive cars are skewing the perception that "average" now means a $50k price of entry for a very average automobile. And that's not true. People who don't understand statistics twist the living heck out of them to mean all sorts of things they don't actually mean.   "Average" new car payment is $1000/month. Yep, it is. And in that number are all the $35k new car buyers who bring significant equity, and the $25k new car buyers who finance the car for a month just to get a rebate, and then pay it off. Know what isn't in that number? All the payments made by people who don't finance a car.   Picking one's own data point (don't have a car payment, never paid $50k for a new vehicle, my house cost $170k, I afforded a middle class lifestyle on $4.50/hr) is just a data point. Just like earning $25/hr in an area where the median home price is almost $1 Million is a data point. In fact, it's a lot of data points given that 80% of the US population lives in/around major cities. They're not idiots; the vast majority of them do it to make a living because that's where the big money is.   The highs have become higher, lows have become lower, and how your personal mileage varies is not truth for an entire country. At the same time you can't NOT acknowledge the data. While it doesn't paint YOUR personal picture, it certainly tints the reality that you also live in, as does your single data point.
    • Glad you had success with it. I did as well, but about 5-6 months later it returned. Tried again, same result. This was after the dealer made several attempts and never even got it to slow down.
    • 3.15 Kroger’s in Montgomery Tx
