Power Folding Mirror problem.
My power folding mirror ( passenger side ) started acting up. When I push the button to fold in the mirror, it struggles and moves a fraction of the distance then stops. I can hear the motor actuating. I have tried resetting it, problem still exists. I have a few questions before trying to fix it.
In my online search it appears the problem could be the worm gear in the folding mechanism.When I look for parts, I can only find the whole mirror. I just need the worm gear. The problem with replacing the whole mirror is that I would then have to get it painted. Expensive and time consuming route.
Here are my questions.
Has anybody been able to just purchase just the worm gear?
If I buy the whole assembly, how difficult is it to take my mirror apart to just replace the gear?
Is the problem the worm gear or is there another cause for one mirror to not completely open and close?
Any info would be appreciated.
Thanks
Keith
What the heck are you driving?? You can add the truck info in name area.
Everyone I have known including me have replaced the entire unit. Talking 900 series here. It is a lot of work/time but easy if you are good at removing door panel and trim etc.....My dealer did mine under warranty and it took a good wrench that had done it before an hour or more...
And they are costly at $220 plus...My other one is now making noise and will one day fail. Seemed to be an issue with the 07-09, along with the door lock actuators.
You can pop everything apart with a screwdriver it's all plastic clips and you'd have to start with the glass. You're better off getting a new mirror. Have you tried manually folding it a few times? That's what we did in the shop that I built them at when they got off track.
sent from my truck in a field
You need to tilt the glass grab a long flat head screw driver and look for the clips that hold it on, pop em the cap should drop off then clip the new cap in place. Be careful not to break clips. Patience is key lol
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 928 Guests (See full list)
